Alle OpenHAB Tutorials
- OpenHAB 3 Camera Binding
- OpenHAB 3 Camera Widget
- OpenHAB 3 in Docker
- OpenHAB 3 MQTT Binding
- OpenHAB Smarthome
- OpenHAB IP Camera Binding
- INSTAR MQTT - OpenHAB2
All OpenHAB FAQs
- OpenHab MQTT Auto-Discovery
Create your Camera
First we need to add our camera as an Equipment. To do this go to Settings and click on Model:
Click on Create Equipment from Thing:
And select your camera that you added using the Camera Binding.
Make sure to click show advanced to see all the channels and tick the Pan, Tilt, Zoom, GoToPreset and MJPEG URL channels as a minimum.
Create the Widget Template
Currently (12.01.2021) the camera widget is not yet part of the standard OpenHAB widgets and has to be created manually. We need to add our widget code via the Developer Tools menu. Click on Create Widget and copy&paste the following code:
uid: ClickablePTZCamera
props:
parameters:
- context: item
label: Select the Camera to Control
required: true
type: TEXT
- context: item
label: Item for Switch
required: false
type: TEXT
- label: Invert Tilt Controls
required: true
type: BOOLEAN
- label: Show Discrete Controls
required: true
type: BOOLEAN
parameterGroups: []
timestamp: Dec 29, 2020, 11:56:36 AM
component: f7-card
config:
class: no-margin
expandable: true
style:
border-radius: 6px
--f7-card-margin-horizontal: 0px
width: 16rem
height: 9rem
slots:
default:
- component: f7-card-content
config:
class: card-opened-fade-out
style:
color: white
background-image: ="url('"+items[props.camera + "_MJPEGURL"].state+"')"
background-size: 17rem 10rem
background-repeat: no-repeat
border-radius: 6px
z-index: -1
config:
class: card-opened-fade-in
style:
color: white
background-size: 100% auto
background-position: center
z-index: -1
- component: oh-link
config:
class: card-prevent-open
style:
margin: 0em 0.2em
color: "=(items[props.switchItem].state === 'ON') ? 'cyan' : 'white'"
opacity: "=(items[props.switchItem].state === 'ON') ? '0.4' : '0.3'"
visible: =props.switchItem !== undefined
iconF7: power
iconSize: 22
action: toggle
actionItem: =props.switchItem
actionCommand: ON
actionCommandAlt: OFF
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
visible: =props.showControls === true
iconF7: arrow_left
iconSize: 22
action: command
actionItem: =props.camera + "_Pan"
actionCommand: INCREASE
config:
class:
- card-prevent-open
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: arrow_up
iconSize: 22
action: command
actionItem: =props.camera + "_Tilt"
actionCommand: "=(props.invertTilt) ? 'INCREASE' : 'DECREASE'"
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: arrow_down
iconSize: 22
action: command
actionCommand: "=(props.invertTilt) ? 'DECREASE' : 'INCREASE'"
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: arrow_right
iconSize: 22
action: command
actionCommand: DECREASE
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: plus
iconSize: 22
action: command
actionItem: =props.camera + "_Zoom"
config:
class:
- card-prevent-open
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: minus
iconSize: 22
action: command
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: list_number
iconSize: 22
action: options
actionItem: =props.camera + "_GoToPreset"
config:
style:
margin: 0 0.2em
color: white
opacity: 0.3
iconF7: gear_alt
iconSize: 22
action: group
actionGroupPopupItem: =props.camera
config:
style:
position: absolute
top: 7.8rem
right: 0.2rem
color: white
opacity: "=(items[props.camera + '_MotionAlarm'].state === 'ON') ? '0.5' : '0'"
iconF7: eye
iconSize: 18
config:
style:
position: absolute
top: 7.7rem
left: 0rem
color: white
opacity: "=(items[props.camera + '_AudioAlarm'].state === 'ON') ? '0.5' : '0'"
iconF7: ear
iconSize: 18Now, when you edit your page, you will have the option to add a Personal Widget with name ClickablePTZCamera:
In Select the Camera to Control select the camera you created in step 1:
The widget allows you to pan&tilt your camera as well as giving you access to your camera's live video and all function that you selected when creating your camera in step 1:
