Alle ioBroker Tutorials
- ioBroker with Docker (Updated 08.04.2024)
- ioBroker on a Raspberry Pi (deprecated)
- INSTAR MQTT - ioBroker
All ioBroker FAQs
- ioBroker v9.1.2 as MQTTv5 Client for your WQHD INSTAR IP Camera
- ioBroker as MQTT Broker for your WQHD Camera
- ioBroker MQTT Alarmserver for your WQHD Camera
- ioBroker REST API with your WQHD Camera
- Using ioBroker with your WQHD Camera
- ioBroker v7 with your WQHD INSTAR MQTTv5 Broker
- Camera Vis with Node-RED
- Live Video and ioBroker VIS
- ioBroker and INSTAR Alarmserver
- ioBroker as MQTT Broker for your Kamera
- ioBroker MQTT Overwrites Camera Settings
- ioBroker and MotionEye Webhooks
- ioBroker w/o MQTT
ioBroker MQTT Adapter cannot connect
Q: I installed my
yellow to green. I checked the log file and it seems that the adapter cannot connect to the MQTT broker on my camera:Try to connect to mqtt://admin:*******************@192.168.2.111:1883?clientId=iobroker
info (3148) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.21.0, js-controller: 3.1.5
info instance system.adapter.mqtt.1 started with pid 3148Make your camera the heart of your smart home
A: Our
!#()*-./<?@[]^_{|}. We tried using this collection of characters as our MQTT login with the MQTT Adapter in client configuration and the connection could not be established (connection status stayed yellow):But if you
