Smarthome Tutorials
Smart Surveillance
Control your camera directly via its HTTP or MQTT interface.
Mike Polinowski
MQTT Topic: Alarm Schedule
Firmware Update
Full HD Series
Mike Polinowski
INSTAR MQTT: Topic Added
Added missing topic for the alarm schedule:
Your camera has 2 alarm schedules - one that determines whether the alarm detection is armed or not and a back-up schedule of the setting you set. This way it is possible to manipulate the alarm schedule for a short time ("Snooze" function) and then restore it from the BackUp. The value displayed in the WebUI is always the BackUp schedule. If you make changes to the schedule via the MQTT API, you should accordingly always switch both schedules at the same time. This is now possible with the following topics:
  • alarm/schedule/dayoftheweek
  • alarm/schedule/dayoftheweek/webui
The latter is intended for the back-up schedule, which is used, among other things, for the display in the WebUI. And the value dayoftheweek is for the day of the week you want to adjust: monday, tuesday, wednesday, usw..
Mike Polinowski
INSTAR MQTT
Firmware Update
Full HD Series
INSTAR Deutschland GmbH
INSTAR MQTT
INSTAR MQTT
Mike Polinowski
IFTTT Applets
Firmware Update
Full HD Series
INSTAR IFTTT Applets
INSTAR IFTTT
Mike Polinowski
Alexa Camera Skill
Firmware Update
Full HD Series
INSTAR Alexa Camera Skill
Control your camera with Alexa terminal
INSTAR Amazon Alexa
We offer both a INSTAR Cloud Skill and a INSTAR Camera Skill in the Alexa Skill Store. For the INSTAR Cloud Skill, all you need is an INSTAR Cloud account and an Alexa device with a display. Add the Skill on your Alexa device and use it directly.
Mike Polinowski
Apple Homekit
Firmware Update
Full HD Series
Apple Homekit
Control your camera with your iPhone or iPad
INSTAR Homekit
The connection to the Homekit service is available from firmware version 3.2(361) (June 2021) for all Full HD models. You can upgrade the firmware of your camera directly via the Web interface.
