Display your Cameras Video inside your Browser
HTML5 Video
Starting with version 2.6 of the web interface, all Full HD camera models support HTML5 Video for plugin-free playback of the video stream. This feature is enabled by default and can be set via the Multimedia/Video Menu.
Flash Video Plugin
All INSTAR HD cameras can display their video stream inside a modern web browser (like Firefox, Chrome or Edge) without the need for a video plugin. Just activate the MJPEG mode for this - e.g. in the Multimedia/Video Menu of your 720p Camera or 1080p Camera. But you will lose the h.264 video compression and might start to suffer from bandwidth bottlenecks inside your network. We highly recommend, that you should install the Adobe Flash Video Plugin and use the h.264 video stream instead. This plugin is already installed on most systems and your camera is configured to use it by default - you should be able to see the video stream at once, after loading your cameras web user interface.
Other Options
If for some reason you cannot use the Flash Video Plugin, there are three more options to display the video stream inside a web browser. You can use the Quick Time Plugin, an ActiveX Plugin (only works with Internet Explorer and Firefox) that comes with a couple of perks or use the above mentioned MJPEG mode to avoid using plugins all together.
Control your camera with Alexa terminal
We offer both a INSTAR Cloud Skill and a INSTAR Camera Skill in the Alexa Skill Store. For the INSTAR Cloud Skill, all you need is an INSTAR Cloud account and an Alexa device with a display. Add the Skill on your Alexa device and use it directly.
Control your camera with your iPhone or iPad
The connection to the Homekit service is available from firmware version 3.2(361) (June 2021) for all Full HD models. You can upgrade the firmware of your camera directly via the Web interface.
Troubleshooting
The video plugin might be blocked by your Firewall or Virus scanner. The following articles will explain how to set up your security software to unblock it.
