INSTAR MQTT Alarmserver Interval
Q: After I changed completely to MQTT, I switched off the
A: Since you usually receive the MQTT alarm server in a Smarthome and define your own actions there, we decided to set the interval as small as possible (1s). So it is intended that you can define your own cool-down interval for the actions in the Smarthome.
You can also adjust the interval of the MQTT alarm server directly on the camera. You can read out the current status on your camera with the following
/param.cgi?cmd=getmdalarm&-aname=server3The default settings are there:
var md_server3_switch="on"; var md_server3_interval="1";If you now want to set the interval to, for example, 5 seconds you can do this with this command:
/param.cgi?cmd=setmdalarm&-aname=server3&-switch=on&-interval=5You get an OK from the camera and the value should now look like this:
var md_server3_switch="on"; var md_server3_interval="5";
