Using the Alarm Relay
Q: I want to switch external light sources with my cameras.
A: I wanted to switch external light sources with my cameras. Find nowhere a hint. I came across her relay board. Nowhere is a technical note on switching capacity or similar.
The camera has already installed an alarm output that is switched via a relay. The board you found is a spare part.
The technical data of the output findes you e.g. on our wiki:
IN-8015 FHD Technical Specifications
IN-7011 HD Technical Specifications
IN-5907 HD Technical Specifications
IN-5905 HD Technical Specifications
Depending on what external light sources you want to switch, you might need to add another dedicated relay in between, as our camera max can switch 30VDC/125VAC @ 1A.
