No Emails
Q: Camera does not send any pictures, although according to my settings all are correct. E-mail test is positive. Manuel can be taken pictures.
A: Under System - System Log you can check if alarm recordings have been made. If there is nothing there, you should again check under the alarm settings whether motion detection is activated and the sensitivity for triggering alarms is high enough. If the alarm settings are correct, it is recommended to install a firmware update on the camera once and possibly reset the camera to the factory settings: If alarms are listed in the system log, check in the alarm settings whether e-mail transmission is activated.
