Switch off your Camera
Q: Can the camera be turned off by app?
A: The camera can only be switched off by disconnecting it from the power supply. However, it is possible to remotely disable the alarm function of the camera via the app. You can also set schedules for alarm recording or manual recording.
Alarm Schedule: 1080p Serie / 720p Serie
App Function (iPhone App): Mobile App
