Alarm Email not sending
Q: Camera does not send pictures
A: Camera does not send any pictures, although according to my settings all are correct. E-mail test is positive. Manuel can be taken pictures.
You can check under System - System Log whether alarm recordings have been made.
If there is nothing there, you should again check under the alarm settings whether motion detection is activated and the sensitivity for triggering alarms is high enough.
If the alarm settings are correct, it is recommended to install a firmware update on the camera once and, if necessary, reset the camera to the factory settings. Falls im System-Log Alarme gelistet sind, überprüfen Sie in den Alarmeinstellungen ob E-Mail-Versand aktiviert.
