IN-7011 HD
Product Overview
| Black / Beige | Black / Beige | approx. 60° | available | only digital |
The IN-7011 HD is a weather proof dome camera which can either be used in in- or outdoor environments. A convenient motor allows for quick readjusting of the lenses viewing direction and can be controlled by any network device such as a tablet or a smartphone. The built-in infrared diodes allows you to see in pitch dark environments, while the integrated IR cut filter aids in the display of vibrant colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on a MicroSD Memory Card with comparably small size but best picture results. The sturdy construction of the camera body guarantees maximum durability and is weather proof for outdoor use.
For surveillance purposes, the IN-7011 HD is ready for implementation to your existing system. But also as a stand-alone device it offers you a number of alarming features like Email Notification or compatibility with Signalling Devices.
Hardware
- Wide Dynamic Range (WDR) 720p Omnivision CMOS Sensor
- High quality aluminium housing
- Remote controlled Pan & Tilt - 350° pan and 100° tilt
- Nightvision with 22 Infrared LED´s @ 850nm (barely visible for the human eye) for distances up to 8 - 12m
- Alarm I/O for external sensors (e.g. Motion or smoke detectors) and receivers (e.g. house automations)
Network
- Compatible with 2.4 GHz 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
- Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
Many built-in features allow you to use this camera not only for surveillance, but also for your personal projects. The FTP Support allows you to use the IN-7011 HD as a multi-functional outdoor webcam for integration on your website.
