IN-5905 HD
Product Overview
Wireless Variant | Power-over-Ethernet Variant | Field of View | Pan & Tilt | Optical Zoom |
White / Black | with ext. PoE Injector | approx. 90° | not available | only digital |
The IN-5905 HD is weather proof and wireless outdoor camera. Built-in, high-powered infrared diodes allow you to see deep into the dark. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on a MicroSD Memory Card with comparably small size but best picture results. The sturdy construction of the camera body guarantees maximum durability and is weather proof for outdoor use.
For surveillance purposes, the IN-5905 HD is ready for implementation to your existing system. But also as a stand-alone device it offers you a number of alarming features like Email Notification or compatibility with Signalling Devices. The WPS function allows you to connect the camera to your WiFi network with a press of a button. Accessing your camera from the internet is even easier. The Point-2-Point connection can be established by scanning a QR code with our smartphone app. The InstarVision mobile app is available for Android, iOS and Windows Phone 8.
IN-5905 HD vs IN-5905 HD
Model | Installed Lense | Lense Upgrade | Night Vision | Body Length |
IN-5907 HD | Standard (approx. 45 degrees) | Yes, Wideangle | 18-25m | 24,8cm without mount |
IN-5905 HD | Wideangle (approx. 90 degrees) | No | 15-20m | 26.3cm with mount |
Comparison between IN-5905 HD and IN-5905 HD
- Slide 1: The camera model IN-5905 HD offers a wide angle lense and should be used at close distance to the area under surveillance - the model is ideal to be installed in entrance areas.
- Slide 2: The wide angle lense enables you to keep an eye over a wide area. But by doubling the field of view on the 720p sensor (compared to the standard lense that is installed in the IN-5905 HD), you lose half of the details inside your image. It is recommend to use the IN-5905 HD for installation at larger distance.
- Slide 3: Installing a big camera close to the area under surveillance, can be distracting. The model IN-5905 HD is constructed to be unobtrusive.
Hardware
- Wide Dynamic Range (WDR) 720p Omnivision CMOS Sensor
- High quality IP65 weatherproof aluminium housing
- Nightvision with 5 Infrared LED´s @ 850nm (barely visible for the human eye) for distances up to 15 - 20m
- Alarm I/O for external sensors (e.g. Motion or smoke detectors) and receivers (e.g. house automations)
Network
- Compatible with 2.4 GHz 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
- Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
Many built-in features allow you to use this camera not only for surveillance, but also for your personal projects. The FTP Support allows you to use the IN-7011 HD as a multi-functional outdoor webcam for integration on your website.
