IN-8403 2k+ WQHD
Product Overview
| White | White | approx. 90° | manually | only digital |
INSTAR IN-8403 2k+ WQHD Night Vision Surveillance Camera (LAN/WLAN) indoor and (IP67) outdoor camera with white light and IR LED night vision, PIR sensor and SD card. 3 second pre-recording before alarm triggers. Smarthome compatibility thanks to Homekit, Alexa Skills, IFTTT and the open CGI & MQTT interface. The compact design of this camera was completely new developed and makes it ideal for discreet surveillance task. The two high power 850nm night vision LEDs are supported by two visible white light LEDs that can be switched on manually or when motion is detected.
The IN-8403 2k+ WQHD surveillance camera is ready for implementation into existing security system. But it also offers you a number of alarm features as a stand-alone device like Email & Push Notification, two-way communication and an alarm siren. The WPS function allows you to connect the camera to your WiFi network with a press of a button. Accessing your camera over the internet is even easier. The Point-2-Point connection can be established by scanning a QR code with our smartphone app. The free InstarVision mobile app is available for Android, iOS, Windows Metro and Windows Phone.
The sensitivity of the integrated Panasonic Pyroelectric Sensor has been significantly improved thanks to a unique slit design of the pyroelectric elements. The separated sensing areas prevent thermal crosstalk between the single sensing elements. This makes a reliable detection possible even if the temperature difference between the background (e.g. floor /wall) and the target object (human body, car engine, etc) is small (around 4°C).
Hardware
- Integrated PIR heat detector for advanced motion detection
- STARVIS 1440p SONY CMOS Sensor
- Built-in microphone incl. noise detection with adjustable max. level, software audio noise and echo reduction
- Built-in PIR motion detector to avoid false alarms
- Two high power white light LEDs that can be activated by alarm triggers
- Additional powerful 850nm IR night vision LEDs (activated manually, by schedule or triggered by the integrated PIR sensor)
- Suitable for wall and ceiling mounting
- MicroSD memory cards up to 256GB possible. (32GB already installed)
Network
- Compatible with WiFi 5GHz / 2.4GHz, Wi‑Fi 5 (802.11ac) for 433 Mbit/s networks with WPA2/WPA3 security
- Integrated personal, free DDNS ("Internet") Address to access your camera over the Internet
Software
- Multi user management and simultaneous login for multiple users with different access rights
- Record 15s alarm videos (+ 3s pre-recording) directly to an Internal SD Card
Security cameras need to be able to record, with clear images, in a variety of environments. Sony's STARVIS* image sensors meet this need by providing high-sensitivity performance suitable for low-light and night recordings. STARVIS* is a back-illuminated pixel technology used in CMOS image sensors for security camera applications. It features highly sensitive backlight illuminated sensor pixels, and realize high picture quality in the visible-light and near infrared light regions. The IMX335 STARVIS* Sensor is a diagonal 2.8 inch CMOS active pixel type solid-state image sensor with a square pixel array and 5.14 M effective pixels.
Activate camera control for your IN-8401, IN-8403 or IN-8415 2k+ WQHD through Alexa using your free INSTAR Cloud account.
Control your INSTAR 2k+ WQHD camera with the Apple Homekit app from your iPhone or iPad.
The SONY STARVIS* IMX335 CMOS sensor features a dynamic range up to 72 dB, advanced HDR functions and digital overlap HDR further improve the image quality and contrast behavior allowing for more detailed image analysis. These features when combined with the low dark current performance further improve its performance in applications demanding a high dynamic range.
* STARVIS is a trademark of the Sony Corporation. A STARVIS sensor is defined by a sensitivity of 2000 mV or more per 1 μm² when illuminated with a 706 cd/m² light source, F5.6 in 1s accumulation equivalent.
