IN-8001 Full HD
Product Overview
Wireless Variant | Power-over-Ethernet Variant | Field of View | Pan & Tilt | Optical Zoom |
White | not available | approx. 90° | not available | only digital |
INSTAR IN-8001 Full HD Night Vision Surveillance Camera (LAN/WLAN) Small but nice indoor camera with invisible 940nm infrared LEDs, PIR sensor and SD card. 3 second pre-recording before alarm. Smarthome compatibility thanks to Homekit, Alexa Skill, IFTTT and CGI & MQTT Interface. The compact design of this camera was completely new developed and makes it ideal for discreet surveillance task. The 6-times 940nm night vision LEDs are invisible to the human eye, making the IN-8001 a suitable baby monitor.
This camera is running an embedded Linux operating system and a Webserver which supports TLS/SSL encryption for security and privacy. It provides a built-in, modern HTML5 based Web User Interface (WebUI) with focus on usability and simplicity, supporting all recent devices (desktop, tablet, smartphone) and operating systems (Windows, MacOS, Linux,…). Thanks to the built-in Camera Setup Wizard and the (built-in) help function, INSTAR users can enjoy a very easy initial set-up of the IP camera.
Hardware
- Integrated PIR heat detector for advanced motion detection
- Wide Dynamic Range (WDR) 1080p Panasonic CMOS Sensor
- Built-in microphone incl. noise detection with adjustable max. level
- Built-in PIR motion detector to avoid false alarms
- 6 x 940nm IR night vision LEDs invisible to the human eye
- Suitable for wall and ceiling mounting
- MicroSD memory cards up to 128GB possible. (16GB already installed ex works)
Network
- Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
The IN-8001 is the newest Full HD PIR Indoor IP Camera from INSTAR. With a built-in passive infrared (PIR) motion sensor and four separately configurable alarm areas that can be linked together, the camera prevents false alarms and notifies you only when a real alarm has been triggered.
Activate camera control through Alexa using your free INSTAR Cloud account.
Control your INSTAR Full HD camera with the Apple Homekit app from your iPhone or iPad.
Equipped with one of the latest Panasonic Full HD CMOS image sensor, which features low noise, high speed and new Wide Dynamic Range (WDR) functionality, the IN-8001 is able to achieve the best image quality in daylight as well as clear image in night vision mode with the help of its high-power LEDs. Hence, the IN-8001 is able to deliver accurate motion detection and alarm notification.
