Product Overview
IN-6001HD
Go to Shop
Indoor surveillance in 720p resolution
INSTAR IN-6001 HD IP Camera
1.) Photodiode for twilight switch, 2.) Infrared LED´s for night vision, 3.) Standard 8mm F/1.2 infrared lense, 4.) Remote controlled camera head, 5.) High quality ABS housing and Internal microphone, 6.) SD card, 7.) DC power supply connector, 8.) WiFi antenna, 9.) Camera Reset, 10.) RJ45 Ethernet connector, 11.) Audio In/Out for external Speaker and Microphones, 12.) Alarm I/O connector for external devices
WiFi VariantPoE VariantField of ViewPan & TiltZoom
White / Blacknot availableapprox. 90°not availabledigital
The IN-6001 HD is the smallest INSTAR HD 720p camera for indoor surveillance inside your office or house. The camera can easily be controlled through your smartphone from inside your network and also over the internet. The camera can easily be connected to your network by using its 108MBit (802.11b/g/n) Wi-Fi module (WPA/WPA2) or through the 100MBit network interface to ensure a fluid video stream. The camera can also see during the night thanks to 8 Infrared LEDs operating at a wavelength of 850nm. The max. indoor range for the cameras night vision is around 5-10 meters. The spiritual successor of the IN-3001 will bring you all the features that you are used to from our VGA series, combined with a superior resolution of 1280x720 Pixel and the possibility to record videos on an integrated SD card. If an alarm is triggered the camera can send an email to notify you. Each email also has 4 pictures attached. This way it will be very easy to check quickly what caused the motion to make sure your home is safe.
Night Vision (min/max) [m]
IN-6001IN-6014IN-5905IN-5907IN-7011IN-8015IN-9008IN-9020
  • min
  • max
Hardware
  • Wide Dynamic Range (WDR) 720p Omnivision CMOS Sensor
  • Automatic IRcut filter for natural colours
  • 4 Infrared LEDs (850nm) for nightvision
  • 2-Way audio via an integrated microphone and speakers
Network
  • RJ-45 Ethernet port for an easy integration into your 100Mbit home network
  • Compatible with 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
  • DHCP and UPnP support for an automatic network integration
  • Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
Field of View (Dia., Hor., Vert.) [°]
IN-6001IN-6012IN-6014IN-5905IN-5907IN-7011IN-8015IN-9008
  • vertical
  • horizontal
  • diagonal
Nightvision [m]MegapixelPower [W]Focal [mm]IR LEDs071425
  • IN-6014 Full HD
  • IN-8015 HD
Nightvision [m]MegapixelPower [W]Focal [mm]IR LEDs06121824
  • IN-6014 Full HD
  • IN-3011
