IN-9808 QFHD
Product Overview
The IN-9808 QFHD is weather proof and wireless outdoor camera. Built-in, high-powered infrared diodes allow you to see deep into the dark. The integrated IR cut filter on the other hand allows for the capturing of native colours during the day, as seen by the human eye. The efficient h.265 compression codec allows recording of alarm videos on an internal SD Memory Card with comparably small file size but best video quality.
The IN-9808 QFHD surveillance camera is ready for implementation into existing security system. But also as a stand-alone device it offers you a number of alarm features like Email & Push Notification, two-way communication and an alarm siren. The WPS function allows you to connect the camera to your WiFi network with a press of a button. Accessing your camera from the internet is even easier. The Point-2-Point connection can be established by scanning a QR code with our smartphone app. The free InstarVision mobile app is available for Android, iOS, Windows Metro and Windows Phone.
The sensitivity of the integrated Panasonic Pyroelectric Sensor has been significantly improved thanks to a unique slit design of the pyroelectric elements. The separated sensing areas prevent thermal crosstalk between the single sensing elements. This makes a reliable detection possible even if the temperature difference between the background (e.g. floor /wall) and the target object (human body, car engine, etc) is small (around 4°C).
Hardware
- STARVIS
*4K (QFHD) 2160p colour CMOS Sensor - Nightvision with 5 Infrared LED´s @ 850nm (barely visible for the human eye) for distances up to 12 - 20m
- Very compact high quality IP66 weatherproof aluminium housing
- Integrated Panasonic Pyroelectric Sensor - PIR Range up to 12m
Network
- Compatible with WiFi 5GHz / 2.4GHz, Wi‑Fi 5 (802.11ac) for 866 Mbit/s networks with WPA2/WPA3/Enterprise security
- Integrated personal, free DDNS ("Internet") Address to access your camera through the Internet
Software
- MicroSD Card Max. 1TB (32GB incl.) for alarm or manual recording
Activate camera control for your IN-9408 or IN-9420 2k+ WQHD through Alexa using your free INSTAR Cloud account.
Control your INSTAR 2k+ WQHD camera with the Apple Homekit app from your iPhone or iPad.
Image Quality
Security cameras need to be able to record, with clear images, in a variety of environments. Sony's STARVIS* image sensors meet this need by providing high-sensitivity performance suitable for low-light and night recordings. STARVIS* is a back-illuminated pixel technology used in CMOS image sensors for security camera applications. It features highly sensitive backlight illuminated sensor pixels, and realize high picture quality in the visible-light and near infrared light regions. The IMX415 STARVIS* Sensor is a diagonal 2.8 inch CMOS active pixel type solid-state image sensor with a square pixel array and 8.29 M effective pixels.
Resolution Comparison
Many built-in features allow you to use this camera not only for surveillance, but also for your personal projects. The FTP Support, for example, allows you to use the IN-9808 QFHD as a multi-functional outdoor webcam for Integration on your Website - for example as a weather cam.
The SONY STARVIS* IMX415 CMOS sensor features a dynamic range up to 72 dB, advanced HDR functions and digital overlap HDR further improve the image quality and contrast behavior allowing for more detailed image analysis. These features when combined with the low dark current performance further improve its performance in applications demanding a high dynamic range.
* STARVIS is a trademark of the Sony Corporation. A STARVIS sensor is defined by a sensitivity of 2000 mV or more per 1 μm² when illuminated with a 706 cd/m² light source, F5.6 in 1s accumulation equivalent.
