IN-8015 Full HD
Product Overview
| White / Black | White / Black | approx. 90° | available | only digital |
IN-8015 Full HD WLAN IP camera for indoor use with 2-way audio, PIR sensor, HTML5 video and web interface. MQTT for smart home integration. Works with Alexa, Homekit and IFTTT. The camera head is remotely controllable and equipped with infrared diodes to utilize night vision in pitch dark environments. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on SD Memory Card with comparably small size but best picture results. Any device (i.e. smartphones) can connect to the cameras web interface and allows you to control the pan & tilt feature. With 350 degrees horizontally and 100 degrees vertically range of movement. Thanks to its compact size and its modern design, you won't be just limited to use it as a surveillance camera but also for your personal projects. The FTP Support allows you to use the IN-8015 HD as a multi-functional webcam for Integration on your Website.
Hardware
- Integrated PIR heat detector for advanced motion detection
- Remote controlled Pan & Tilt - 350° pan and 100° tilt
- 2-Way audio via an integrated Microphone & Speaker
- Wide Dynamic Range (WDR) 1080p Panasonic CMOS Sensor
Network
- Compatible with 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
- Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
Image Quality
The 1/3 inch WDR sensor is a Panasonic CMOS chip, enabling 1080p HD video at unparalleled low-light sensitivity. Panasonic offers a wide variety of image sensors (νMaicovicon®) for security and network cameras, which are based on the industry's most advanced technology and can be applied to security cameras requiring high picture quality with high sensitivity and low noise. The CMOS image sensor, νMaicovicon®, features high picture quality equal to high-speed CCD technologies, high S/N ratio, low noise, and high dynamic range. Even in a dark condition, you can retrieve snapshots with excellent character detection, color reproduction, as well as object detection. Even in scenes with fast-moving objects, the image sensor ensures clear images without motion blur or strain. The frame composite function (WDR) enables high-dynamic range - you can simultaneously resolve dark and bright areas in your video frame.
Resolution Comparison
** The Model IN-6012 HD only offers half the resolution, compared to the IN-8015 HD, but - with its reduced angle of view - still offers a very detailed image. The camera model IN-6014 HD uses a similar lense as the IN-8015 HD, with a slightly a bigger field of view because of its slightly bigger sensor and wider lense.
Activate camera control through Alexa using your free INSTAR Cloud account.
Control your INSTAR Full HD camera with the Apple Homekit app from your iPhone or iPad.
The IN-8015 Full HD is the first INSTAR HD 1080p pan & tilt camera with an integrated infrared motion detector. The camera can easily be controlled through your smartphone from inside your network and also over the internet. The camera can easily be connected to your network by using its 2.4GHz (802.11b/g/n) Wi-Fi module (WPA/WPA2/CCMP) or through the 100MBit network interface to ensure a fluid video stream. The camera can also see during the night thanks to 10 Infrared LEDs operating at a wavelength of 850nm. The max. indoor range for the cameras night vision is around 5-10 meters. Our new fullHD indoor camera will bring you all the features that you are used to from our 720p series, combined with a superior resolution of 1920x1080 Pixel and the possibility to record videos on an integrated SD card. The IN-8015 HD is the camera that combines the powerful software based motion detection with a hardware heat motion detector (PIR). Both methods can be used or bundled to increase their effectiveness by minimizing their false alarm rate.
