Homebridge INSTAR MQTT to Homekit
- Preparing the Homebridge Docker Image
- Commit your Changes to the Docker Image
- Hombridge Configuration Template
Homebridge is a lightweight NodeJS server you can run on your home network that emulates the iOS HomeKit API. It supports Plugins, which are community-contributed modules that provide a basic bridge from HomeKit to various 3rd-party APIs provided by manufacturers of "smart home" devices.
Control your camera with Alexa terminal
We offer both a INSTAR Cloud Skill and a INSTAR Camera Skill in the Alexa Skill Store. For the INSTAR Cloud Skill, all you need is an INSTAR Cloud account and an Alexa device with a display. Add the Skill on your Alexa device and use it directly.
Control your camera with your iPhone or iPad
The connection to the Homekit service is available from firmware version 3.2(361) (June 2021) for all Full HD models. You can upgrade the firmware of your camera directly via the Web interface.
Download
Start by downloading the Docker image from Docker Hub. It is recommended to use the latest version:
docker pull oznu/homebridge:latestHow to Run
Homebridge requires full access to your local network to function correctly which can be achieved using the --net=host flag. Currently this image will not work when using Docker for Mac or Docker for Windows.
You can run the image with the following command:
docker run \
--net=host \
--name=homebridge \
-e PUID=<UID> -e PGID=<GID> \
-e TZ=Europe/Berlin \
-e HOMEBRIDGE_CONFIG_UI=1 \
-e HOMEBRIDGE_CONFIG_UI_PORT=8080 \
-e HOMEBRIDGE_INSECURE=1 \
-v </path/to/config>:/homebridge \
oznu/homebridgeThe </path/to/config> has to be created on your host system, e.g. :
mkdir /opt/homebridge
chmod 775 /opt/homebridgeSometimes when using data volumes (-v flags) permissions issues can arise between the host OS and the container. We avoid this issue by allowing you to specify the user PUID and group PGID. Ensure the data volume directory on the host is owned by the same user you specify and it will "just work".
In this instance PUID=1001 and PGID=1001. To find yours use id user as below:
id <dockeruser>
uid=1001(dockeruser) gid=1001(dockergroup) groups=1001(dockergroup)Configuration
Create a file name config.json inside the /opt/homebridge directory. A template can be found at the end of this tutorial. This configuration file will add 10 MQTT buttons for the Full HD camera with the IP address 192.168.2.117 and Admin Login admin / instar running it's MQTT Broker on port 1883 with the broker login admin / instar. Please changes these information inside the configuration file before copying it to the directory.
But we are not yet able to use this template as it requires 2 plugins we need to install first. So we have to start with a blank template, start up Homebridge and install the those plugins first.
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:35",
"manufacturer": "homebridge.io",
"model": "homebridge",
"port": 51826,
"pin": "031-45-155"
"description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
"ports": {
"start": 52100,
"end": 52150,
"comment": "This section is used to control the range of ports that separate accessory (like camera or television) should be bind to."
"accessories": [],
"platforms": [
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "dark-mode",
"tempUnits": "c",
"lang": "auto",
"sudo": false,
"accessoryControl": {
"debug": true
"platform": "config"
}Add this content to /opt/homebridge/config.json:
nano /opt/homebridge/config.json
chmod 775 /opt/homebridge/*Run
You have already downloaded the image, now you can check the Image ID and run the container:
docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
localhost/oznu/homebridge latest f0039cfe89f4 46 hours ago 726 MBAdd your Image ID, Docker User and Group ID, Timezone and configuration directory to the following command:
docker run \
--net=host \
--name=homebridge \
--privileged \
--rm \
-e PUID=0 -e PGID=0 \
-v /opt/homebridge:/homebridge \
-ti -u root f0039cfe89f4 /bin/bashSetting Up Homebridge
Wait for the Homebridge UI to spin up on Port 8080 and login with admin / admin:
You can install the following plugins through the Hombridge UI:
- homebridge-camera-ffmpeg
- homebridge-mqttthing
When installing the homebridge-camera-ffmpeg plugin you will be asked to fill out the following form to add your camera:
For this camera:
- LAN IP
192.168.2.117 - RTSP Port
554 - Admin Username
admin - Admin Password
instar
You will have to add these two lines (change them according to your camera configuration):
-re -i rtsp://admin:instar@192.168.2.117:554/12
-i http://192.168.2.117/tmpfs/auto.jpg?usr=admin&pwd=instarThis will add the following lines to our configuration file:
With the MQTT plugin installed, we can import the MQTT Buttons in the accessories section of the configuration file - the necessary code can be found at end of this tutorial. Again, this code is for the camera with the following configuration and has to be adjusted accordingly:
- Camera LAN IP
192.168.2.117 - MQTT Broker Port
1883 - MQTT User
admin - MQTT Password
instar
Add the complete accessories section to your file to add all MQTT buttons:
Login to your host machine from a new terminal window and find out the Container ID that was assigned to the homebridge container:
docker ps -a
CONTAINER ID IMAGE NAMES
5b4bd0d0189d localhost/oznu/homebridge:debian-no-avahi homebridgeIn this case the Container ID is 5b4bd0d0189d and I want to call the image, that will contain all our changes, instar-mqtt-homebridge:
docker commit 5b4bd0d0189d instar-mqtt-homebridgeWe can now stop the original image and switch to our newly created image:
docker images
REPOSITORY IMAGE ID
localhost/instar-mqtt-homebridge 42e1bcaed5e6The old container has the ID 5b4bd0d0189d - so we can stop this now and run the new image with Image ID 42e1bcaed5e6 instead:
docker stop 5b4bd0d0189dTo run the new image you have to modify the following command as before - but this time either use the Image ID 42e1bcaed5e6 or Repository Name localhost/instar-mqtt-homebridge you have to assigned to your new image:
docker run \
--net=host \
--name=instar-mqtt-homebridge \
--privileged \
--rm \
-ti -u root 42e1bcaed5e6 /bin/bashWhen you access the Homebridge dashboard you should now find all MQTT buttons under the Accessories tab (Click and configure them, if you want to add them to your main dashboard page):
"bridge": {
"port": 51826,
"pin": "031-45-155"
"ports": {
"start": 52100,
"end": 52150,
"accessories": [
"accessory": "mqttthing",
"type": "switch",
"name": "Alarm Area 1",
"manufacturer": "INSTAR",
"model": "IN-8015 FullHD",
"serialNumber": "1234567889",
"firmwareRevision": "0.1",
"url": "http://192.168.2.117:1883",
"username": "admin",
"password": "instar",
"caption": "Alarm Area 1",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/area1/enable",
"apply": "return JSON.parse(message).val;"
"setOn": {
"topic": "instar/local/alarm/area1/enable",
"apply": "return JSON.stringify({val: (message)})"
"onValue": "1",
"offValue": "0",
"confirmationPeriodms": 1000,
"retryLimit": 3
"type": "switch",
"name": "Alarm Area 2",
"serialNumber": "1234567891",
"caption": "Alarm Area 2",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/area2/enable",
"setOn": {
"topic": "instar/local/alarm/area2/enable",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"type": "switch",
"name": "Alarm Area 3",
"serialNumber": "1234567892",
"caption": "Alarm Area 3",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/area3/enable",
"setOn": {
"topic": "instar/local/alarm/area3/enable",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"type": "switch",
"name": "Alarm Area 4",
"serialNumber": "1234567893",
"caption": "Alarm Area 4",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/area4/enable",
"setOn": {
"topic": "instar/local/alarm/area4/enable",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"type": "switch",
"name": "PIR Sensor",
"serialNumber": "1234567894",
"caption": "PIR Sensor",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/actions/pir/enable",
"setOn": {
"topic": "instar/local/alarm/actions/pir/enable",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"type": "switch",
"name": "Link Areas",
"serialNumber": "1234567895",
"caption": "Link Areas",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/actions/linkareas",
"setOn": {
"topic": "instar/local/alarm/actions/linkareas",
"onValue": "on",
"offValue": "off",
"retryLimit": 3
"type": "switch",
"name": "Alarm Email",
"serialNumber": "1234567896",
"caption": "Alarm Email",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/actions/email",
"setOn": {
"topic": "instar/local/alarm/actions/email",
"onValue": "on",
"offValue": "off",
"retryLimit": 3
"type": "switch",
"name": "Alarm Push",
"serialNumber": "1234567897",
"caption": "Alarm Push",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/alarm/push/enable",
"setOn": {
"topic": "instar/local/alarm/push/enable",
"onValue": "on",
"offValue": "off",
"retryLimit": 3
"type": "switch",
"name": "Audio",
"serialNumber": "1234567898",
"caption": "Audio",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/multimedia/audio/enable/high",
"setOn": {
"topic": "instar/local/multimedia/audio/enable/high",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"type": "switch",
"name": "Preset Position",
"serialNumber": "1234567899",
"caption": "Preset Position",
"mqttOptions": {
"keepalive": 30
"mqttPubOptions": {
"retain": true
"logMqtt": true,
"topics": {
"getOn": {
"topic": "instar/local/status/features/ptz/preset",
"setOn": {
"topic": "instar/local/features/ptz/preset",
"onValue": "1",
"offValue": "0",
"retryLimit": 3
"platforms": [
"name": "Config",
"port": 8080,
"auth": "form",
"tempUnits": "c",
"lang": "auto",
"sudo": false,
"debug": true
