IN-2905
Product Overview
INSTAR IN-2905v2
The IN-2905 v2 is the successor of the popular IN-2905. Dozens of Upgrades makes this camera on par with the more high-end line of INSTAR cameras. It now features an IR cut filter in order to display nice and clear colours during the daytime. Further you will find Audio I/O and IN-Motion 300) for the addition of optional speakers or microphones (e.g. IN-Mikro 380) to use the camera as a 2-way communication system. The IN-2905 V2 is the perfect surveillance camera for businesses and private households. The casing out of high quality aluminium can be installed outside and thanks to its compact size inside the office or house without being seen right away. The sturdy construction of the camera body guarantees maximum durability and is weather proof for outdoor use.
This camera model can easily be connected to your network by using its 54MBit (802.11b/g/n) Wifi module or through the 100MBit network interface. This will ensure a fast stream of the cameras video.
For surveillance purposes, the IN-2905 v2 is ready for implementation to your existing system. Home Automation Systems as well as NAS Systems like Synology or QNAP are have integrated our cameras into their products. You will find profiles to the corresponding cameras within the systems software. But also as a stand-alone device it offers you a number of alarming features like Email Notification or compatibility with signalling devices.
Hardware
  • Nightvision with 24 Infrared LED´s @ 850nm (barely visible for the human eye) for distances up to 12 - 15m
  • High quality IP65 weatherproof aluminium housing
  • Alarm I/O for external sensors (e.g. motion or smoke detectors) and receivers (e.g. house automations)
Network
  • RJ-45 Ethernet port for an easy integration into your 100Mbit home network
  • Compatible with 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
  • DHCP and UPnP support for an automatic network integration
  • Integrated personal, free DDNS ("Internet") Address
Software
