INSTAR Deutschland GmbHINSTAR Deutschland GmbH
Product Overview
IN-8015 Full HD
Go to Shop
Indoor surveillance in 1080p resolution
Photodiode for twilight switch, 2.) Infrared LED´s for night vision, 3.) Standard 4.2mm F/2.1 infrared lense, 4.) Remote controlled camera head, 5.) PIR heat detector for advanced motion detection, 6.) SD card, 7.) Audio Out (3.5mm Headphone Jack), 8.) RJ45 Ethernet connector, 9.) WiFi antenna connector, 10.) Status LED, 11.) Alarm I/O, 12.) Reset / WPS Button, 13.) DC power supply connector
WiFi VariantPoE VariantField of ViewPan & TiltZoom
White / Blacknot yet availableapprox. 90°availabledigital
Remark: All images and description on this page correspond to the WiFi variant.
Nightvision Distance
IN-6001 HDIN-6014 HDIN-5905 HDIN-5907 HDIN-7011 HDIN-8003 FHDIN-8015 FHDIN-9008 FHDIN-9020 FHD
[0] min [m]
[1] max [m]
The IN-8015 Full HD is an all-round solution for 1080p indoor surveillance. The camera head is remotely controllable and equipped with infrared diodes to utilize night vision in pitch dark environments. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on SD Memory Card with comparably small size but best picture results. Any device (i.e. smartphones) can connect to the cameras web interface and allows you to control the pan & tilt feature. With 350 degrees horizontally and 100 degrees vertically range of movement. Thanks to its compact size and its modern design, you won't be just limited to use it as a surveillance camera but also for your personal projects. The FTP Support allows you to use the IN-8015 HD as a multi-functional webcam for Integration on your Website .
Power Consumption[W]
Booting min [W]Booting max [W]Booting with IR active [W]Idle [W]Idle with IR active [W]Idle with IR & WiFi active [W]Pan or Tilt [W]Pan or Tilt with IR active [W]Video Recording active [W]Video Recording with IR active [W]
[0] IN-3011
[1] IN-6012 HD
[1] IN-8003 FHD
[2] IN-8015 FHD
Hardware
  • Integrated PIR heat detector for advanced motion detection
  • Remote controlled Pan & Tilt - 350° pan and 100° tilt
  • 2-Way audio via an integrated Micorphone & Speaker
  • Wide Dynamic Range (WDR) 1080p Panasonic CMOS Sensor
Network
  • RJ-45 Ethernet port for an easy integration into your 100Mbit home network
  • Compatible with 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
  • DHCP and UPnP support for an automatic network integration
  • Integrated personal, free DDNS ("Internet") Address and P2P User ID to access your camera through the Internet
Software
Image Quality
The 1/3 inch WDR sensor is a Panasonic CMOS chip, enabling 1080p HD video at unparalleled low-light sensitivity. Panasonic offers a wide variety of image sensors (νMaicovicon®) for security and network cameras, which are based on the industry' s most advanced technology and can be applied to security cameras requiring high picture quality with high sensitivity and low noise. The CMOS image sensor, νMaicovicon®, features high picture quality equal to high-speed CCD technologies, high S/N ratio, low noise, and high dynamic range. Even in a dark condition, you can retrieve snapshots with excellent character detection, color reproduction, as well as object detection. Even in scenes with fast-moving objects, the image sensor ensures clear images without motion blur or strain. The frame composite function (WDR) enables high-dynamic range - you can simultaneously resolve dark and bright areas in your video frame.
Field of View
IN-6001 HDIN-6012 HDIN-6014 HDIN-5905 HDIN-5907 HDIN-7011 HDIN-8003 FHDIN-8015 FHDIN-9008 FHD
[0] diagonal [°]
[1] horizontal [°]
[2] vertical [°]
Resolution Comparison
IN-8015 HD vs IN-6014 HDIN-8015 HD vs IN-6014 HD
IN-8015 HD vs IN-6012 HDIN-8015 HD vs IN-6012 HD
** The Model IN-6012 HD only offers half the resolution, compared to the IN-8015 HD, but - with its reduced angle of view - still offers a very detailed image. The camera model IN-6014 HD uses a similar lense as the IN-8015 HD, with a slightly a bigger field of view because of its slightly bigger sensor and wider lense.
The IN-8015 Full HD is the first INSTAR HD 1080p pan & tilt camera with an integrated infrared motion detector. The camera can easily be controlled through your smartphone from inside your network and also over the internet. The camera can easily be connected to your network by using its 2.4GHz (802.11b/g/n) Wi-Fi module (WPA/WPA2/CCMP) or through the 100MBit network interface to ensure a fluid video stream. The camera can also see during the night thanks to 10 Infrared LEDs operating at a wavelength of 850nm. The max. indoor range for the cameras night vision is around 5-10 meters. Our new fullHD indoor camera will bring you all the features that you are used to from our 720p series, combined with a superior resolution of 1920x1080 Pixel and the possibility to record videos on an integrated SD card. The IN-8015 HD is the camera that combines the powerful software based motion detection with a hardware heat motion detector (PIR). Both methods can be used or bundled to increase their effectiveness by minimizing their false alarm rate.
IN-8015FHD vs IN-6012HD
4.85.66.47.28.01.21.41.61.82.06.46.87.27.68.08.48.89.29.6108.89.6101112focalmegapixelpowernightvisionirleds
IN-8015FHD vs IN-3011
4.85.66.47.28.01.21.41.61.82.06.46.87.27.68.08.89.61011128.89.6101112focalmegapixelpowernightvisionirleds
The 1/3 inch WDR sensor is built on a 4.3 micron OmniPixel3-HS™ Pixel enabling 720p HD at unparalleled low-light sensitivity and a dynamic range in colour of 115 dB – compared to the 60 db of a regular VGA IP Camera. WDR allows you to capture high detailed colour videos even in high-contrast environmental lighting conditions
