IN-9010 Full HD
Product Overview
Wireless Variant | Power-over-Ethernet Variant | Field of View | Pan & Tilt | Optical Zoom |
White / Black | not available | approx. 40 - 120° | available | 3x |
The IN-9010 Full HD is the newest Full HD outdoor pan / tilt / zoom IP camera from INSTAR. Four separately configurable alarm areas that can be linked together, the camera prevents false alarms and notifies you only when a real alarm has been triggered.
Equipped with one of the latest Panasonic Full HD CMOS image sensors, which features low noise, high speed and new Wide Dynamic Range(WDR) functionality, the IN-9010 is able to achieve the best image quality in daylight as well as clear image in night vision mode with the help of its high - power LEDs.Hence, the IN - 9020 is able to deliver accurate motion detection and alarm notification.
The design of this outdoor camera was completely new developed in order to fullfill the wishes of our customers.Therefore, it is now very easy to pull the connection cable through the wall as it is much smaller, you won´ t have to drill huge holes into your wall anymore.Furthermore, thanks to the new concept design, a crystal clear vision, day and night, is ensured, because the camera does not require a dome dome anymore.
Hardware
- Full HD WDR Panasonic CMOS sensor / resolution 1920 x 1080px
- Varied focal autofocus lense: 2.8mm ~ 12mm ( 36 ~ 120º diagonal field of view)
- SD Card with max. 128GB (16GB incl.) for alarm, manual and continuous recording
- Integrated microphone for sound recording
- Alarm-out Relay - switches external alarm devices (for example a Siren)
Network
- Free point-2-point (P2P) connectivity with InstarVision, works with IPv6
- Free DDNS address to connect to your camera via the internet
- Optional upload & management of alarm videos in the INSTAR Cloud
- Upload alarm images / videos to an FTP server (FTP or secure FTPS)
- 2.4Ghz WiFi with IEEE 802.11b/g/n and WPA/WPA2 encryption (only WiFi model)
- Access the WebUI via HTTPS with secure TLS/SSL encryption
Software
- Privacy Mask areas for privacy concerns
- Define four Motion Detection Areas for software motion detection
- Supports motion, heat and noise detection
- Alarm videos pre-triggered 3s before the trigger event
- Alarm emails and push (text) notifications in case of an alarm trigger
- Send alarm triggers to third party devices such as home automations
- 15s alarm video / scheduled / manual continuous recording on SD
- Supports stream protocols like RTSP, RTP, RTMP, MJPEG...
- Interval snapshots for website integration or time lapse videos
Activate camera control through Alexa using your free INSTAR Cloud account.
Control your INSTAR Full HD camera with the Apple Homekit app from your iPhone or iPad.
The 1/3 inch WDR sensor is a Panasonic CMOS chip, enabling 1080p HD video at unparalleled low-light sensitivity. Panasonic offers a wide variety of image sensors (νMaicovicon®) for security and network cameras, which are based on the industry's most advanced technology and can be applied to security cameras requiring high picture quality with high sensitivity and low noise. The CMOS image sensor, νMaicovicon®, features high picture quality equal to high-speed CCD technologies, high S/N ratio, low noise, and high dynamic range. Even in a dark condition, you can retrieve snapshots with excellent character detection, color reproduction, as well as object detection. Even in scenes with fast-moving objects, the image sensor ensures clear images without motion blur or strain. The frame composite function (WDR) enables high-dynamic range - you can simultaneously resolve dark and bright areas in your video frame.
IN-9010FHD vs IN-7011HD
IN-9010FHD vs IN-4011
This camera is running an embedded Linux operating system and a Webserver which supports TLS / SSL encryption for security and privacy.It provides a built - in , modern HTML5 based Web User Interface(WebUI) with focus on usability and simplicity, supporting all recent devices(desktop, tablet, smartphone) and operating systems(Windows, MacOS, Linux, …).Thanks to the built - in camera setup wizard and the(built-in ) help function, INSTAR users can enjoy a very easy initial set - up of the IP camera.
