IN-5905 Full HD Manual
INSTAR IN-5905 HD
The IN-5905 HD is weather proof and wireless outdoor camera. Built-in high-powered infrared diodes allow you to see deep into the dark. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on a MicroSD Memory Card with comparably small size but best picture results.
For surveillance purposes, the IN-5905 HD is ready for implementation to your existing system. But also as a stand-alone device it offers you a number of alarming features like Email Notification or compatibility with Signalling Devices.
Many built-in features allow you to use this camera not only for surveillance, but also for your personal projects. The FTP Support allows you to use the IN-5907 HD as a multi-functional outdoor webcam for integration on your website.
