IN-4010
Product Overview
INSTAR IN-4010v2
The IN-4010 is a dome camera for outdoor use and thanks to its pan and tilt motor it can capture the whole area. The PTZ functions can be manipulated by any computer or smartphone device and allows a comfortable way to change the position of the cameras lense. A clear picture is achieved through it optical zoom lense. In contrast to conventional upscaling the variable focal length ensures zooming capabilities with satisfying picture results. The IN-4010 comes with an active microphone which allows you to capture all noises or use it to trigger alarm events if a specific volume level is reached.
This camera model can easily be connected to your network by using its 54MBit (802.11b/g/n) Wifi module or through the 100MBit network interface. This will ensure a fast stream of the cameras video.
For surveillance purposes, the IN-4010 is ready for implementation to your existing system. Home Automation Systems as well as NAS Systems like Synology or QNAP are have integrated our cameras into their products. You will find profiles to the corresponding cameras within the systems software. But also as a stand-alone device it offers you a number of alarming features like Email Notification or compatibility with signalling devices.
Hardware
  • Remote controlled Pan & Tilt outdoor camera with a 4 times optical zoom
  • Very compact high quality IP65 weatherproof aluminium housing
  • Alarm I/O for external sensors (e.g. motion or smoke detectors) and receivers (e.g. house automations)
Network
  • RJ-45 Ethernet port for an easy integration into your 100Mbit home network
  • Compatible with 2.4 GHz WiFi IEEE 802.11 b/g/n up to 54Mbit networks with WEP, WPA and WPA2 security
  • DHCP and UPnP support for an automatic network integration
  • Integrated personal, free DDNS ("Internet") Address
Software
