IN-8403 2k+ WQHD Manual
# | Component | Function |
| 01 | Bracket | Sealing bracket for the main camera body |
| 02 | Photosensor | Twilight switch for IR LEDs |
| 03 | Status LEDs | Red: Camera constant on after power on or blinking during firmware update. Blue: On with WiFi connection, blinking using WPS or reset |
| 04 | Dual LEDs | 2 high-power IR LEDs ( @ 850nm). 2 high-power floodlight LEDs |
| 05 | Lense | Wide-angle (focal length: 4.3mm / field of view: approx. 90º dia.) |
| 06 | PIR Sensor | Integrated passive infrared (PIR) motion detector |
| 07 | Microphone | For noise detection / audio rec. |
| 08 | Micro SD Card | Slot for MicroSD/SDXC cards (max. 128GB - 32GB included) - inside the camera |
| 09 | Alarm Input | Input for potential free external alarm sensors |
| 10 | Alarm Output | Output relay can support max. 24V/1A |
| 11 | Reset | Press 15-20 seconds for reset |
| 12 | Network LED | Off: No Power / No signal, Flashing: Network Signal |
| 13 | Network Port | RJ45 LAN port / connector for Cat5e LAN cable or higher |
| 14 | Power Connector | For included 12V / 1A power supply |
The IN-8403 2k+ WQHD is the newest 1440p PIR In- and Outdoor IP Camera from INSTAR. With a built-in passive infrared (PIR) motion sensor and four separately configurable alarm areas that can be linked together, the camera prevents false alarms and notifies you only when a real alarm has been triggered.
Equipped with one of the latest SONY STARVIS 1440p CMOS image sensor, which features low noise, high speed and exceptional low-light capabilities, the IN-8403 2k+ WQHD is able to achieve the best image quality in daylight as well as clear image in night vision mode.
Use the IN-8403 2k+ WQHD camera a baby or pet monitor using the invisible set of LEDs or activate the stronger 850nm LEDs to provide enough light to fill out an entire room. The second LED set can also be coupled to the motion detection - add the stronger LEDs when the PIR body heat sensor is triggered.
This camera is running an embedded Linux operating system and a Webserver which supports TLS/SSL encryption for security and privacy. It provides a built-in, modern HTML5 based Web User Interface (WebUI) with focus on usability and simplicity, supporting all recent devices (desktop, tablet, smartphone) and operating systems (Windows, MacOS, Linux,…). Thanks to the built-in Camera Setup Wizard and the (built-in) help function, INSTAR users can enjoy a very easy initial set-up of the IP camera.
Status LEDs
Mode | Blue LED | Red LED |
| Constant on | Connected to WiFi | N/A |
| Slow Flashing | Connecting via WPS | Camera operational |
| Fast Flashing | No connection to WiFi | Upgrading firmware |
| Off | LED is disabled or Camera has no Power | LED is disabled or Camera has no Power |
