Quick Installation
For the wall mount installation, there are two ways to install the IN-8001 FullHD camera.
Wall mount by Magnet
The camera holds a magnet in the bottom of the stand. Use the round metal plate and install it to the wall. Then simply attach the stand to the metal plate and adjust the orientation to your needs.
IN-8001 Full HD Installation
Direct Wall mount
Alternatively, install two screws directly in the wall or ceiling and then attach the camera stand using the arresting lock.
