IN-8001 Full HD Manual
# | Component | Function |
| 01 | Photosensor | Twilight switch for IR-LEDs |
| 02 | Infrared-LEDs | 6 IR-LEDs (@ 940nm) - invisible to the human eye |
| 03 | Lense | Wide-angle (focal length: 4.3mm / field of view: ~ 90º dia.) |
| 04 | Microphone | For noise detection / audio rec. |
| 05 | PIR-Sensor | Integrated passive infrared (PIR) motion detector |
| 06 | Speaker | Integrated loudspeaker |
| 07 | Antenna | Built-in 3dB Antenna |
| 08 | Camera Label | P2P ID, LAN MAC address and serial number |
| 09 | Status LED | Red: Power; Blue: Network Status; Both can be disabled. |
| 10 | WPS / Reset | 3 seconds for quick WiFi setup / 15-20 seconds for reset |
| 11 | SD Card Reader | Slot for MicroSD/SDXC cards (max. 128GB - 16GB included) - inside the camera |
| 12 | Mounting Thread / Bracket | The bracket can be used as wall mount or ceiling mount when connected to either one of the two mounting threads |
| 13 | Power Connector | For included 5V / 1.5A Power Supply |
| 14 | Network Port | RJ45 LAN port / connector for Cat5e LAN cable or higher |
| 15 | Screw Lock | For desk-top, wall and ceiling installation |
| 16 | Built-in Magnet | For wall mount use together with metal mounting plate |
The IN-8001 is the newest Full HD PIR Indoor and Outdoor IP Camera from INSTAR. With a built-in passive infrared (PIR) motion sensor and four separately configurable alarm areas that can be linked together, the camera prevents false alarms and notifies you only when a real alarm has been triggered.
Equipped with one of the latest Panasonic Full HD CMOS image sensor, which features low noise, high speed and new Wide Dynamic Range (WDR) functionality, the IN-8001 is able to achieve the best image quality in daylight as well as clear image in night vision mode with the help of its high-power LEDs. Hence, the IN-8001 is able to deliver accurate motion detection and alarm notification.
The design of this camera was completely new developed in order to fullfill the wishes of our customers. If you need to pull the cable through the wall, a small hole in the size of the cable diameter would be sufficient, as you can simply take off the cable from inside the casing, pull it through the wall and connect the cable back to the board inside.
This camera is running an embedded Linux operating system and a Webserver which supports TLS/SSL encryption for security and privacy. It provides a built-in, modern HTML5 based Web User Interface (WebUI) with focus on usability and simplicity, supporting all recent devices (desktop, tablet, smartphone) and operating systems (Windows, MacOS, Linux,…). Thanks to the built-in Camera Setup Wizard and the (built-in) help function, INSTAR users can enjoy a very easy initial set-up of the IP camera.
Status LEDs
Mode | Blue LED | Red LED |
| Constant on | Connected to WiFi | Connected to WiFi |
| Slow Flashing | Connecting via WPS | Connecting via WPS |
| Fast Flashing | N/A | N/A |
| Off | LED is disabled or Camera has no Power | LED is disabled or Camera has no Power |
