All ioBroker Tutorials
All ioBroker FAQs
Home Assistant on Raspberry Pi
Related Articles:
Hassio
Installing the Raspberry Pi Linux image on your Raspberry Pi:
Download the program Etcher and flash the following image onto your SD Card:
https://github.com/home-assistant/operating-system/releases/download/5.13/hassos_rpi4-64-5.13.img.xzInsert the SD card into your Raspberry Pi and plug in the power supply to boot up the system. This will automatically start the installation process.
Within a few minutes you will be able to reach Home Assistant on homeassistant.local:8123. If you are running an older Windows version or have a stricter network configuration, you might need to access Home Assistant at homeassistant:8123 or http://X.X.X.X:8123 (replace X.X.X.X with your Raspberry Pi’s IP address).
Now continue with the OnBoarding Steps.
