Heating Element Installation
Q: Is it possible to install a heater on the camera?
A: In most cases, the use of a heater is not necessary because the camera generates even in continuous operation sufficient heat. However, if you plan to turn off the camera occasionally in winter - or if you suspect power outages - it may happen that the case cools down and the camera can only be put back into operation after warming up above 0 ° C. In such a case, a heater in the housing helps:
IN-5905 HD Heater Installation
IN-5907 HD Heater Installation
IN-7011 HD Heater Installation
