INSTAR Deutschland GmbH
Bigger SD Card
Q: Can I use a larger SD card with my camera?
A: With the 720p cameras you can use SD cards up to 32GB and with the 1080p up to 128GB. For indoor cameras, the SD card reader sits in the back or side of the case and the card can easily be exchanged for a larger one.
For the outdoor cameras, the housing must first be opened before you get to the SD card:
IN-9008 Full HD Lense Adjustment
IN-9008 Full HD SD Card Upgrade
IN-7011 HD SD Card Upgrade
IN-5905 HD microSD Card
IN-5905 HD swap the MicroSD Card
IN-5907 HD Heater Installation
IN-5907 HD SD Card Upgrade
