IN-9808 QFHD Manual
Product Features
# | Component | Function |
| 01 | Infrared LEDs | 5x High-power infrared LED´s for night vision @850nm |
| 02 | Lense | Wide Angle (focal length 4.2mm / 100º field of view) |
| 03 | Photo sensor | Twilight Switch for IR LEDs |
| 04 | PIR Detector | Integrated Panasonic PIR Motion Detector |
| 05 | Microphone | For Noise Detection / Audio Recording / Two-way Audio Communication |
| 06 | Audio Output | 3.5mm Jack for Earphone / Active Speaker |
| 07 | Network Port | RJ45 LAN Port for the provided CAT5e Ethernet Cable (or higher) |
| 08 | Power Connector | For included 3m, 12V / 2A dc, 100 - 240V power supply |
| 09 | Micro SD Card | Slot for MicroSD/SDXC Cards up to 1 TB (32 GB included) |
| 10 | WPS / Reset | 3 seconds for WPS WiFi setup / 15s sec. for reset / 20s sec. for reset (incl. network settings) / 30s sec. for reset to last installed firmware version. |
| 11 | Status LEDs | Red: Power, Blue: Network Status |
| 12 | Antenna Connector | 2x RP-SMA WiFi Antenna Connector |
| 13 | WiFi Antenna | 2x 3,5db Antenna (RP-SMA) |
| 14 | Cable Feedthrough | IP66 Weatherproof with Rubber Sealing for 3, 2 or 1 Cables. Please check out our Quick Installation Guide on how to attach your Camera Cables |
| 15 | Sealing Ring | Rubber Sealing Rings for 3, 2 or 1 Cables. Please check out our Quick Installation Guide on how to attach your Camera Cables |
| 16 | Nut | To close the Cable Feedthrough and Weather Seal it. |
| 17 | Bracket | Wall- and Ceiling-Mount. |
Status LEDs
Mode | Blue LED | Red LED |
| Constant on | Connected to WiFi | N/A |
| Slow Flashing | Connecting via WPS | Camera operational |
| Fast Flashing | No connection to WiFi | Upgrading firmware |
| Off | LED is disabled or Camera has no Power | LED is disabled or Camera has no Power |
