IN-9020 Full HD Manual
# | Component | Function |
| 01 | Wall Bracket | Wall mounting |
| 02 | Ceiling Bracket | Overhead installation |
| 03 | Antenna Connector | RP-SMA WiFi antenna connector (not for PoE version) |
| 04 | Infrared LED | 6 high-powered IR LEDs (nightvision @ 850nm) |
| 05 | Autofocus Lense | Varied focus with autofocus optical lens (2.8mm ~ 12mm) |
| 06 | Photo Sensor | Twilight switch for IR LEDs |
| 07 | PIR Sensor | Integrated Panasonic passive infrared (PIR) motion detector |
| 08 | Microphone | For noise detection and audio recording |
| 09 | MicroSD card slot | For noise detection / audio rec. |
| 10 | Network LED | Slot for MicroSD/SDXC cards (max.128GB - 16GB included) |
| 11 | Alarm Output | Indicator for network status - On: connected to network / Off: No power or no network |
| 12 | Network Port | Supports alarm output for external signaling device |
| 13 | Power Connector | RJ45 LAN port / connector for Cat5e LAN cable or higher |
| 14 | Extension Cable | For included 12V / 2A power supply |
| 15 | Antenna Connector | RP-SMA WiFi Antenna Connector (not for PoE version) |
