IN-8401 2k+ WQHD Manual
# | Component | Function |
| 01 | Photosensor | Twilight switch for IR-LEDs |
| 02 | Infrared-LEDs | 6 IR LEDs (invisible @940nm) and 4 IR LEDs (slightly red visible @850nm) |
| 03 | Lense | Wide-angle (focal length: 4.3mm / field of view: ~ 90º dia.) |
| 04 | Microphone | For noise detection / audio rec. / two-way audio intercom |
| 05 | PIR-Sensor | Integrated passive infrared (PIR) motion detector |
| 06 | Status LED | Red: Power; Blue: Network Status; Both can be disabled. (see LED modes, below) |
| 07 | Speaker | Integrated loudspeaker |
| 08 | Antenna | Built-in 3dB Antenna |
| 09 | Camera Label | P2P ID, LAN MAC address and serial number |
| 10 | WPS / Reset | Three seconds for WPS WiFi setup / 20 seconds for reset |
| 11 | SD Card Reader | Slot for MicroSD/SDXC cards (max. 256GB - 32GB included) - inside the camera |
| 12 | Mounting Thread / Bracket | The bracket can be used as wall mount or ceiling mount when connected to either one of the two mounting threads |
| 13 | Power Connector | For included 5V / 2A power supply |
| 14 | Network Port | RJ45 LAN port / connector for Cat5e LAN cable or better |
| 15 | Screw Lock | For desk-top, wall and ceiling installation |
| 16 | Built-in Magnet | For wall mount use together with metal mounting plate |
The IN-8401 2k+ WQHD is the newest WQHD PIR Indoor IP Camera from INSTAR. With a built-in passive infrared (PIR) motion sensor and four separately configurable alarm areas that can be linked together, the camera prevents false alarms and notifies you only when a real alarm has been triggered.
Equipped with one of the latest SONY STARVIS 1440p CMOS image sensor, which features low noise, high speed and exceptional low-light capabilities, the IN-8401 2k+ WQHD is able to achieve the best image quality in daylight as well as clear image in night vision mode with the help of its dual LEDs with 940nm (invisible) and 850nm (light red glow) wavelength emissions.
Use the IN-8401 2k+ WQHD camera a baby or pet monitor using the invisible set of LEDs or activate the stronger 850nm LEDs to provide enough light to fill out an entire room. The second LED set can also be coupled to the motion detection - add the stronger LEDs when the PIR body heat sensor is triggered.
This camera is running an embedded Linux operating system and a Webserver which supports TLS/SSL encryption for security and privacy. It provides a built-in, modern HTML5 based Web User Interface (WebUI) with focus on usability and simplicity, supporting all recent devices (desktop, tablet, smartphone) and operating systems (Windows, MacOS, Linux,…). Thanks to the built-in Camera Setup Wizard and the (built-in) help function, INSTAR users can enjoy a very easy initial set-up of the IP camera.
Status LEDs
Mode | Blue LED | Red LED |
| Constant on | Connected to WiFi | N/A |
| Slow Flashing | Connecting via WPS | Camera operational |
| Fast Flashing | No connection to WiFi | Upgrading firmware |
| Off | LED is disabled or Camera has no Power | LED is disabled or Camera has no Power |
