IN-8015 Full HD Manual
# | Component | Function |
| 01 | Photo sensor | Twilight-Switch for IR LEDs |
| 02 | Lense | Wideangle lense (focal length: 4.2mm / field of view: 72.3.º hor.) |
| 03 | Infrared-LEDs | 10 IR LEDs (nightvision @ 850nm) |
| 04 | Camera Head | Controllable via the User Interface and Smartphone App |
| 05 | PIR Detector | Integrated Passive Infrared Motion Detector |
| 06 | MicroSD Card Slot | Slot for SD/SDHC cards (up to 128 GB - 16 GB included) |
| 07 | Audio Out | 3.5mm earphone / active speaker jack |
| 08 | Network Port | RJ45 LAN-port for the provided CAT5e LAN cable (For the power supply according to IEEE802.3af only in case of the IN-8015 HD PoE!) |
| 09 | Antenna Connector | SMA WiFi antenna connector (Not available in case of the IN-8015 HD PoE model!) |
| 10 | LED Indicator | Red - Switchable Status-LED for network traffic |
| 11 | Alarm I/O | Alarm Output (1&2) / Input (3&4) |
| 12 | Reset Button | Reset your camera settings to the factory defaults |
| 13 | Power Connector | 5V / 1.5 A DC - Plug Ø : 1.35mm (in) / 3.5mm (out) |
| 14 | Camera ID | MAC address LAN and QR for the P2P connection |
| 15 | Stand Mount | Standard camera thread for provided stand support |
The IN-8015 Full HD is the successor of the IN-6012 HD camera solution for indoor surveillance and the first indoor camera with integrated passive-infrared motion detection. The camera head is remotely controllable and equipped with infrared diodes to utilize night vision in pitch dark environments. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on a SD memory card with comparably small size but best picture results. Any device (i.e. smartphones) can connect to the cameras web interface and allows you to control the pan & tilt feature. With 350 degrees horizontally and 100 degrees vertically the pan and tilt feature basically covers the whole area in front of the camera. Thanks to its compact size and its modern design, you won't be just limited to use it as a surveillance camera but also for your personal projects. The FTP support allows you to use the IN-8015 HD as a multi-functional webcam for integration on your website.
