IN-8015 Full HD Manual
Lense Adjustment
The IN-8015 Full HD is the first INSTAR HD 1080p pan & tilt camera with an integrated infrared motion detector. The camera can easily be controlled through your smartphone from inside your network and also over the internet.
Adjust the Focus of your IN-8015 Full HD
The IN-8015 HD’s lense offers a limited field depth that was adjusted to a field between 1m to 8m. In case the object you want to observe lies outside of this area, you will have to adjust the lense accordingly.
Connect the camera to the power supply and the network cable. Open the web interface and use the included tool to turn the lense until you can see a clear and sharp picture.
