IN-6012 Full HD Manual
The IN-6012 HD is the successor of the IN-3011 VGA camera solution for indoor surveillance. The camera head is remotely controllable and equipped with infrared diodes to utilize night vision in pitch dark environments. The integrated IR cut filter on the other hand allows for the capturing of native colours, as seen by the human eye. Through the use of an efficient h.264 compression codec it is able of recording video files on a SD memory card with comparably small size but best picture results. Any device (i.e. smartphones) can connect to the cameras web interface and allows you to control the pan & tilt feature. With 350 degrees horizontally and 100 degrees vertically the pan and tilt feature basically covers the whole area in front of the camera. Thanks to its compact size and its modern design, you won't be just limited to use it as a surveillance camera but also for your personal projects. The FTP support allows you to use the IN-6012 HD as a multi-functional webcam for integration on your website.
