Pan & Tilt Tour
Q: Can one adjust a swivel range? Want to monitor front door and garden door at the same time.
A: You can define positions. Depending on what the camera is currently seeing (ie at which position it is) this area is then monitored. You can also automatically drive the camera from one position to the other, but such a tour is possible up to a maximum of 50x and then has to be restarted. If you want to monitor two areas at the same time, it makes more sense to use two fixed cameras instead of one controllable so that you can continuously monitor both areas.
