No Alarm In/Output
Q: Alarm input and output was saved or see this wrong?
A: The alarm input is used by the integrated PIR motion detector. And unfortunately there is no alarm output on the IN-6014 HD.
Here you would have to use the IN-6012HD which has an alarm on output. The 4.3 mm wide-angle, which is already installed in the IN-6014 HD, is also available for retrofitting for the IN-6012HD.
