MQTT Sensor Video Overlay
Q: I am using an MQTT/Zigbee/Z-Wave sensor and would like to display its readings as an overlay over the video image of my camera. Is it possible to add a data stream to the video image of my camera?
A: Here is an example how to solve this problem in Node-RED via the INSTAR MQTT Interface and the Image Overlay.
Enable the overlay
In the example above, I added an option to enable and disable the sensor overlay via the multimedia/overlay/showname MQTT-Topic. You can replace the Inject Nodes with incoming triggers - for example, when the sensor readout exceeds a safe value:
Node-RED Flow Export
[{"id":"fe5510d0.fada1","type":"mqtt out","z":"9c94ad40.eea84","name":"multimedia/overlay/showname","topic":"cameras/117/multimedia/overlay/showname","qos":"1","retain":"false","broker":"7553a41d.22b8bc","x":319,"y":58,"wires":[]},{"id":"e3f4cbf0.f0d0d8","type":"inject","z":"9c94ad40.eea84","name":"OFF","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"val\":\"0\"}","payloadType":"json","x":110,"y":80,"wires":[["fe5510d0.fada1"]]},{"id":"46aa340.db0f0cc","type":"inject","z":"9c94ad40.eea84","name":"ON","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"val\":\"1\"}","payloadType":"json","x":110,"y":40,"wires":[["fe5510d0.fada1"]]},{"id":"7553a41d.22b8bc","type":"mqtt-broker","name":"192.168.2.117","broker":"192.168.2.117","port":"8883","tls":"c411fab7.e16228","clientid":"","usetls":true,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"c411fab7.e16228","type":"tls-config","name":"","cert":"","key":"","ca":"","certname":"mqtt_client-new.crt","keyname":"","caname":"","servername":"","verifyservercert":false}]Adding the data stream
I use a random number generator to simulate the sensor readout. The readout is then sent as a payload to a MQTT Out node for the MQTT-Topic multimedia/overlay/cameraname - replacing the camera name in the camera image with the sensor readout.
[{"id":"ad54e87a.837728","type":"mqtt out","z":"9c94ad40.eea84","name":"multimedia/overlay/cameraname","topic":"cameras/117/multimedia/overlay/cameraname","qos":"1","retain":"false","broker":"7553a41d.22b8bc","x":471,"y":122,"wires":[]},{"id":"a4fdb5a5.dd1ee8","type":"function","z":"9c94ad40.eea84","name":"Sensor","func":"random=Math.round(Math.log(Math.floor(Math.random() * 100) + 1) * 1000) / 1000;\nmsg.payload='{\"val\":\"Rad%3A%20'+ random + '%20Bq\"}'\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":253,"y":122,"wires":[["ad54e87a.837728"]]},{"id":"7c6c476.68d89b8","type":"inject","z":"9c94ad40.eea84","name":"Intervall","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":110,"y":122,"wires":[["a4fdb5a5.dd1ee8"]]},{"id":"7553a41d.22b8bc","type":"mqtt-broker","name":"192.168.2.117","broker":"192.168.2.117","port":"8883","tls":"c411fab7.e16228","clientid":"","usetls":true,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"c411fab7.e16228","type":"tls-config","name":"","cert":"","key":"","ca":"","certname":"mqtt_client-new.crt","keyname":"","caname":"","servername":"","verifyservercert":false}]Overlay Position
If you need to position the overlay at the bottom of the image, you can use the following CGI SET command:
/param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Rad%3A%204.563%20Bq&-place=1
/param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Rad%3A%204.563%20Bq&-place=0The parameter place places the overlay either at the top or bottom of the left edge of the video image. To read out the current setting, you can use the following GET command:
/param.cgi?cmd=getoverlayattr&-region=1
