Installation without a PC
Q: Is it necessary to install the camera on the PC or is the app for the smart phone also sufficient?
A: As a first installation you should definitely use a PC with a web browser to make the basic settings and scan the QR code with the Instar app. After initial setup, you can then conveniently control the camera via your Smart Phone.
