INSTAR and Synology Surveillance Station
UPDATE: Full HD cameras IN-8015 Full HD, IN-9008 Full HD, IN-9010 Full HD, IN-9020 Full HD are now fully supported
Q: Can the camera be operated with the Synology Surveillance Station?
A: Yes, the camera can be easily used with Synology.
Currently Synology is still integrated, the camera can be the trigger for a recording. Currently Synology itself would do the motion detection, with an update Synology will then also support the function that gives the camera the trigger for recording. So then PIR motion detector on the camera can be the trigger for the alarm.
