Our customer forum - ask your questions about INSTAR IP cameras, INSTAR software and general smarthome and security solutions.
Knowledgebase for everything IP Camera Surveillance and Smart Living
Q: Is it possible to disable the WLAN?
A: Yes, you can easily disable Wi-Fi.
If you have connected the camera via LAN cable, WLAN would also be automatically deactivated. You can also deactivate this manually in the web interface of the camera.
1080p Serie / 720p Serie
