Deactivate PIR Sensor
Q: Can you turn off the PIR sensor?
A: Yes, this is easily possible. You can either do not use motion detection at all, only use software-based motion detection through an image comparison, use the PIR individually, or couple the PIR and the alarm areas of the software-based motion detection. All combinations are possible.
