Deactivate Motion Detection
Q: Is it possible to disable the alarm with the app?
A: The camera also turns on in the evening at 20 o'clock but unfortunately not automatically in the morning at 7 o'clock. The thief-icon on my phone is still red.
The schedule turns on motion detection. The red male in the app turns off the alarm areas. That You can use the schedule to set time windows in which motion detection is active. Using the button in the app, you can manually bypass the alarm by disabling the panels - this is for example when you need to monitor and briefly enter an area (for example, a storage room).
If the schedule has disabled motion detection, however, it is not possible to enable it using the button in the app - i. even if the male is red, no alarm will be triggered.
