Connection Failures
Q: The connection to the camera breaks off again and again.
A: The connection to the camera breaks down again or is not liquid.
If the connection to the camera is unstable, it is most likely due to the wireless LAN connection from camera to router. Check under Network - WLAN if the camera has a Wi-Fi signal strength over 60 to your router, then one can assume a liquid connection. If the signal is weaker, it is worthwhile to realign the router or the camera, or to use a wireless repeater. We also offer extension cables for the antenna of outdoor cameras:
Extension CableA wired connection, if possible, is always preferable to the Wi-Fi connection.
