Bad WiFi
Q: Although the WLAN signal is perfect, the connection often breaks off.
A: Although the wireless signal strength is perfect, the connection is constantly breaking. I've already tried everything and even set a repeater in between and measured the WiFi strength with the phone.
You can search for networks in the WebUI of the camera under Network / WLAN (
If you have previously used other repeaters, it would be important that they do not have the same SSID as the main router. Since the camera goes only after the SSID and connects to it, it may happen that the camera otherwise connects to the wrong access point, which may then be far away and thus has only a bad connection.
In routers such as the AVM Fritzbox you have the opportunity once the wireless channels to scan through to see if the Fritzbox and the repeater eventual use a wireless channel, which is heavily used in the area. If there are a lot of devices on the same channel, then I recommend you change the channel manually. Disturbing WLAN signals can disturb not only the connection between repeater and camera, but also the connection between repeater and router.
In addition, one should check which encryption the router or the repeater use. The mixed mode WPA + WPA2 should not be used. It's best to use the WPA2 (AES / CCMP). Of course, you should first make sure that the cameras have selected the WPA2 and AES modes.
The mixed mode is usually only used if you have very old WLAN devices in use that do not support WPA2. Since WPA no longer offers security, you should not use it.
