No FireMotD ExportFile detected
If you see the Error message FireMotD: Info: No FireMotD ExportFile detected
after starting openHABian for the first time, follow this Guide to get FireMotD set up:
- Go to the FireMotD directory
cd /opt/FireMotD
- And run the following command
sudo ./FireMotD -I -v
(you will be prompted to use the root password that is openhabian by default)
- When you restart your Pi you will now be greeted by the useful FireMotD output.
