OpenHAB v3 Sitemaps für Ihren WQHD INSTAR MQTTv5 Broker
- Teil I - Konfiguration der MQTT-Binding über die Main Benutzeroberfläche
- Teil II - MQTT-Bindingskonfiguration über die Konfigurationsdateien
- Teil III - MQTT Binding Rules
- Teil IV - MQTT Binding Scripts
- Teil V - Guppen und Sitemaps
Grouping your Items
A: Part 1 of this tutorial installed the OpenHAB MQTT binding and connected it to the internal broker in our INSTAR WQHD camera using the OpenHab 3 Main UI. The Part II did the same by editing the configuration files of our OpenHab 3 installation. In Part III we added some automations using the OpenHab Rules feature. And now it is time to build a dashboard by grouping items and building a sitemap.
To goup your Items create a file groups.items in the ./items directory:
// Location
Group office "Office"
// Floors
Group basement "Basement" (office)
Group ground_floor "Ground Floor" (office)
Group first_floor "First Floor" (office)
Group front_entrance "Front Entrance" (office)
// Rooms
Group reception "Reception" (ground_floor)
Group hallways "Hallways" (ground_floor,first_floor)
Group offices "Offices" (ground_floor,first_floor)
Group storage "Storage" (basement,first_floor)
Group outdoor "Outdoor" (front_entrance)
// Sorted by Function
// Cameras
Group cameras "Cameras" (office)
Group cam_basement "Basement Cameras" (cameras,basement)
Group cam_ground "Ground Floor Cameras" (cameras,ground_floor)
Group cam_first "First Floor Cameras" (cameras,first_floor)
Group cam_entrance "Entrance Cameras" (cameras,front_entrance)
// Sorted by Binding
// MQTT
Group mqtt "MQTT" (office)
Group mqtt_cameras "MQTT Cameras" (mqtt)We can also pre-define Item Types that we want to use in the ./items directory inside a file named itemtypes.items:
Group Cam_group "Type Group" <group> (office)
Switch PrivacyAreas "Type Switch [MAP(INSTAR.map):%s]" <switch> (it_group)
Dimmer Cam_Dimmer "Type Dimmer [%.0f %%]" <chart> (it_group)
Color Cam_Color "Type Color [%s]" <colorpicker> (it_group)
Number Cam_Number "Type Number [%.2f °C]" <temperature> (it_group)
String Cam_String "Type String" <error> (it_group)
Image Cam_Image "Type Image" <camera> (it_group)
Location Cam_Location "Type Location" <presence> (it_group)Now we can assign a group to our items:
Switch PrivacyAreas "All Privacy Areas" <camera> (reception,cam_entrance,mqtt_cameras) {channel="mqtt:topic:home:PrivacyArea1, mqtt:topic:home:PrivacyArea2,mqtt:topic:home:PrivacyArea3,mqtt:topic:home:PrivacyArea4"}And your Item will now be part of the assigned groups:
The Group Items will also be shown in the Model tab:
Sitemaps
Sitemaps are one way to select and compose these elements into a user-oriented representation for various User Interfaces (UIs), including the openHAB app for Android. Sitemaps are text files with the .sitemap extension, and are stored in the $OPENHAB_CONF/sitemaps directory:
sitemaps/INSTAR.sitemap
sitemap cameras label="Camera Surveillance" {
Frame label="Camera 118" {
Default item=Home label="Home"
Switch item=PrivacyAreas
}Save the sitemap and open the basic UI on http://localhost:8080/basicui/app?sitemap=INSTAR. You should now be able to see the Privacy Areas switch:
We can use the MapTransformation addon to change the text that is being displayed here:
We now have to define the transformation we want to perform. This can be done in:
transform/INSTAR.map
ON=Private
OFF=Not PrivateTo perform the transformation we can now link the map file to the switch in our items/itemtypes.item:
