Alarm FTP Upload
FTP Settings for 1080p Cameras
Set the FTP upload during alarm and photo series
Your IP camera can upload pictures and videos either during a motion alarm or in a time interval. The configuration can be set in the web interface of your camera inside the FTP Settings menu.
Alarm FTP Upload Setup for the 1080p Camera Series
After setting your FTP configuration, continue with our Motion Detection Setup Guide to activate the FTP upload in case of an alarm event.
Category
Connection
FTP ServerPlease enter the address of your FTP server. In the example above we have used a AVM Fritzbox (Router) as a FTP server. This router has a USB Stick connected which provides the storage for the pictures. In our case we have to type in the IP address of the router. If you want to set up your own FTP server on your local computer, you will find a step by step manual here. You can also use a web address as the FTP Server. This can either be an online host service or a DynDns address which connects to a FTP server at another location.
FTP PortPlease type in the FTP Servers port which is usually 21.
FTP FolderFill in the folder you want to upload the pictures inside. By default the folder will be "./" which means that the camera will save the uploads in the root folder of the server. In our above sample the pictures will be saved in the root folder.
FTP UsernamePlease fill in the username of your FTP account. The default username for the AVM Fritzbox is "ftpuser".
FTP Password Please fill in the password of your FTP account.
FTP ModeHere you can choose between (PASV) and active Mode (PORT). The default setting is the mode PORT with which the camera will tell the server its IP and Port. Therefor this mode will also work with passive FTP servers. If the client is behind a router which will use NAT or if a firewall is blocking the clients network from accessing the network, then you should choose the PASV mode.
Next please apply all settings and test them afterwards to make sure the settings are correct.
INSTAR Forum
