ioBroker MQTT Adapter cannot connect
Q: I installed my
camera according to your guide in ioBroker
. But the adapter connection status does not switch from yellow
to green
. I checked the log file and it seems that the adapter cannot connect to the MQTT broker on my camera:Try to connect to mqtt://admin:*******************@192.168.2.111:1883?clientId=iobroker
info (3148) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.21.0, js-controller: 3.1.5
info instance system.adapter.mqtt.1 started with pid 3148
Mike Polinowski
INSTAR MQTT
Firmware Update
Full HD Series
Mike Polinowski
IFTTT Applets
Firmware Update
Full HD Series
A: Our
ioBroker Guide
uses the MQTT service of your INSTAR Full HD camera as your MQTT broker. Accordingly, you have to set the MQTT Adapter to Client/subscriber mode and connect it to your camera. But we found that the adapter, configured as an MQTT client, does have issues with special characters inside the MQTT login. The INSTAR MQTT Broker supports the following special characters !#()*-./<?@[]^_{|}
. We tried using this collection of characters as our MQTT login with the MQTT Adapter in client configuration and the connection could not be established (connection status stayed yellow
):But if you
configure the adapter as your MQTT Broker
you will be able to use all those characters listed above (see screenshot above - the broker instance of the MQTT Adapter is running using the same login).
