INSTAR Deutschland GmbH
WiFi Frequency Standard
Q: Which W-LAN and frequency standards does the camera support? Also 5 Ghz?
A: No, since most customers attach more importance to a long range of WLANs, only a 2.4Ghz WLAN module is installed because 5Ghz would not be so strong from the distance. The camera supports the 2.4GHz frequency band with the b / g / n standard
  • WLAN authentication: WEP, WPA, WPA2
  • WLAN encryption type: TKIP, AES
