INSTAR Deutschland GmbH
Minimum Focus Distance
Q: Is it possible to focus on ants at close range?
A: Yes, that is easily possible. All you have to do is turn the front of the lens until you reach the desired sharpness. You can do this eg. see also the structure of your skin, you have to turn as I said only on the lens to set this to the desired sharpness.
